looking for these pieces for a '72 510. LMK what you have. thank you
DONE:::::::::WTB: 510 Rear axle shaft assy and flange
Re: WTB: 510 Rear axle shaft assy and flange
I have these pieces,axle shaft with grease sling shield,bushing btw outer bearing & back of wheel stud flange, bearing spacer, 2 bearings, half shaft flange, washer & nut. All this for $150 each plus S&H.
Dean
gzentas510@outlook.com
Dean
Just make sure if you need the bearing spacers that the letter stamped on them matches the letter stamped on the swing arm, very important.
