1. AP 7 1/2" Competition 2 plate clutch $100
2. 240Z type Caliper new $25
3. Heavy Duty AP pressure plate $30
4.(2) Solidhub friction plate 7 1/2" $20 each
5.6 bolt L series aluminum Fylwheel $100
6. (2)shallow front wheel rotors 10 1/2" for 510??? $$25 each
7. (2) deep front wheel rotors 10 1/2" for 510 or 240 $25 each
8. 12"Nissan 6 bolt aluminum flywheel $100
9. 12" stock steel 5 bolt flywheel $10 each
10. 12" flexplates $10 each
11. 71/2" stock heavy duty clutch plate $20
12. (13) engine/trans separator plates $3 each
13. (4) coleman 10" brake rotors new in box $20 each
15 solid steel comp flywheel 6 bolt $20
16.solid steel flywheel 5 bolt $20 each
17 Ring gear for small flywheel $10
18.(2) floating axel hub covers aluminum $20
19. (2) floating axel hub and brake disc covers aluminum $30 each
21. Aluminum rear differential cover $5
22. MSD ignition kit (coil and wires etc) $300
23 MSD misc parts grab bag $15
25. Nissan stok starters $10
26.(4) Wilwood 120-6806 brake calipers new in box $40 each
27.full float solid rear end axle from 510 wagon$50
28. 510-adjustable front camber plates $20 each
29.I-O port roll bar camera mount $40
30. TDC formula car 2 stage dry sump pump$300
31. (4) L-16 front covers $10 each
32 Heavy Duty L-16 /L24 water pumps $20 each
33. L-20 front covers $20
34 (4) Coilover Carrera shocks $40 each
35. :-4 nissan dry sump pan project.$20
36. Nissan gear reduction starter$50
37.L-16-L-18 (using normal racing head)4-1 tubular exhaust manifold$50
38.4-1 tubular headers (needs collector)$20
39. (12) custom short billett aluminum air horns for 44 weber carbs $10 each
40.ARE aluminum dry sump pan like new $250
If you want to bundle several parts and combine shipping we can discount
Local pickup on large items suggested
WTS Bill Partridge has discounted parts for liquidation
Re: WTS Bill Partridge has discounted parts for liquidation
Pm Sent
Where are these parts Located at?
The parts are located near Indianapolis, Indiana. where are you located ?
Bill,
- I am interested in some parts you have for my SCCA ITC 510.
- AP 7 1/2" competition 2 plate clutch for $100. Will this fit in a stock bellhousing? Used or new?
- AP pressure plate for $30. Does this go with the 7 1/2" clutch? Used or new? Do you have a TO bearing for the trans shaft?
- What is the weight of the aluminum fly wheel?
- Stock steel flywheel for $10 as I want to severely balance another flywheel to come close to the weight of the aluminum flywheel and replace the stock flywheel in the car.
- Do you have any stock engine parts - head, oversized pistons, crank?
What state are you in as I travel from FL to New England a few times a year and can pick up.
Jim Bell
jimjeanbell@gmail.com
Jim Bell
Bill,
Forgot to ask, do you have a stock steering box in good shape?
Jim
Jim
I’m interested in the camber plates and coil overs if you still have them.
Could you shoot me some pics?
Thanks,
Rob
Thanks,
Rob
