FS: R160 LSD Rear Differential from a GC8 Impreza WRX STI
It's VLSD. 4.11 Gear Ratio. You'll need c-clip grooves machined into your 510 stub axles to make them work. Other than that it should bolt in.
$350.00 SHIPPED... Pics posted below. Shipping is going to be robust cause this bitch have some weight to it.
Re: FS: R160 LSD Rear Differential from a GC8 Impreza WRX STI
You're going to need the correct VLSD stubs for the VLSD to work.JDM Dime wrote:It's VLSD. 4.11 Gear Ratio. You'll need c-clip grooves machined into your 510 stub axles to make them work.
Ditto what Julian said.
Also, the 510 does not have "male stubs" for a diff like that. It has female threaded flanged adapters.
Basically, you need to get a diff that has "outies" not "innies".
To the original poster, you might have better luck selling it on RS25 or Nasioc, or some other subaru boards.
- thisismatt
What? The 510 has male stubs with a hole all the way down the shaft for the bolt that screws into the center section, on the left in this picture:Compression wrote:Ditto what Julian said.
That's an older style subaru male-male stub shaft on the right.
I'm your huckleberry.
whoops, thanks for the correction. Been a long time since I swapped a subie diff.
Regardless, this diff is not compatible with 510 stubs, right?
www.betamotorsports.com has stubs that make this rearend work in a 510. this is what i am using
http://www.betamotorsports.com/products ... php?cat=11
^That? 'Cause that's going to engage the VLSD.
