mattyhacks71
Post by mattyhacks71 » 01 Dec 2015 18:00
abisel wrote:^^^
Looks like you have a ton of clearance. Are you going to mount a K&N filter? Also, I see your MC has the nipples on the outboard side. Can you tell me the MC brand and size?
No I'm going to make some little gauze filters for the stacks and leave them like that.
It's a 7/8" bore master from a 280z I believe. It's stiff. Do a quick search on here for what year you can get, they will bolt on without modification.
mell00510
Post by mell00510 » 03 Dec 2015 19:59
I actually didnt do shit! but....
Santa dropped off my sandblasted gifts early!! :D
Post by 510rob » 04 Dec 2015 01:41
is that a 2-stroke Lawn Boy under the bench?
Post by Three B's Racing » 14 Dec 2015 10:34
Today? Nothing but over the weekend I did install my 9.5-10 OEM `69 top in. The one everyone wanted but said because it was to pricey but were eager to spend $400-$500 on a bumper. But that's ok because it sure looks like new in my 510.
jovial_cynic
Post by jovial_cynic » 07 Feb 2016 18:40
Do you know what happens when previous owners of engines are lazy and they install the knock sensor in the wrong location? Well, if the sensor is in the bolt-hole right next to the location where the engine and transmission meet, your knock sensor thinks you are pinging out at all times, and the timing gets pulled so much you bog out amd have a red-hot exhaust.
Previous owners. Sigh.
Got that fixed today, and NOW I know what an sr20det is supposed to feel like!
71 510 2-door SR20DET (S13)
http://www.myagentjosh.com
http://www.newprotest.org/510
Post by icehouse » 10 Feb 2016 08:03
Picked up a VQ35 for a good deal. Test fit it into my front clip. Must build drift 510!!
Mattndew76
Post by Mattndew76 » 10 Feb 2016 11:21
:shock:
Post by bertvorgon » 11 Feb 2016 07:02
I spent a few hours both changing my oil and draining the oil cooler. I let it drain for a day, as it is so cool in the back of my work.
I also changed out the flexible hose between my breather pipe and my catch can. The heat just bakes the plastic tubing and it be comes very hard. I like it to be able to absorb the engine vibration without it transmitting to the catch can too badly.
Next project will be to change out the drivers door seal, as it has gotten very tired after 38 years. I put new ones on when I built the car in 1978.
My vintage Boler trailer also got it's furnace burner assembly fixed, which I am just tickled about. It would be like dragging out an old 1600 motor, rebuilding the carb and throwing some new plugs and wires on it, and then it will pull 100MPH! I have had the trailer for over 20 years now and having some nice warm heat on cold mountain nights keeps things cozy.
IMGP0832 (Large).JPG (277.74 KiB) Viewed 1574 times
IMGP0846 (Large).JPG (306.92 KiB) Viewed 1574 times
IMGP0842 (Large).JPG (410.56 KiB) Viewed 1574 times
IMGP0841 (Large).JPG (433.69 KiB) Viewed 1574 times
abisel
Post by abisel » 14 Mar 2016 07:03
Added a couple electric fans 'cause the Champion 3-row radiator left no clearance for the stock fan and an aftermarket fan was heavy and slightly out of balance.
  • A pair of Spal 9" pushers.
    2 Relay harnesses.
    A 2x2 sheet of 13 gauge 1/2" expanded sheet metal from hardware store.
    A couple strips of aluminum to mount the expanded metal to the front of the radiator support.
    A 4-way ATO fuse box with double sided tape to hold fuse box in place.
    Radiator hose thremoswitch with 185/165 set-points.
    Assorted crimp connectors and heat shrink tubing.
    Assorted stainless steel metric fasteners.
    Assorted tools.
    Zip ties.
    A can of Rustoleum satin black.
The system is wired so the fans will run when ignition is turned off. Also have a by-pass switch on the dash to operate the fans independent of the thermoswitch.
Spal recommended 15 amp fuses, but each fan is rated at 6 amps continuous, so I tried a 7.5 amp fuse which failed at fan start-up (motors draw the largest current at start-up). Went to 10 amp fuses and fans start and run just fine. Fuses are meant to protect the wiring, not the component, so the smallest fuse is best.
Works good. Need to see how it performs this summer. Also, the thermoswitch is a good way to see if your stock temperature gauge is accurate.
greenthumb
Post by greenthumb » 14 Mar 2016 12:49
just curious on the placement of the fan switch thermostat. Is that it on the upper rad hose, or is that sensor for the gauge?
What is the consensus on the best practices placement of the fan controller thermostat? Wouldn't you want the trigger to be measuring as the water exits the radiator at the botom of the rad? If the temp there is above x* the fans would switch on as the convective cooling is no longer keeping up.
abisel
Post by abisel » 14 Mar 2016 14:46
I have heard both arguments about where to place the fan thermoswitch. I chose the upper radiator hose to catch the water temperature as it exits the engine into the top of the radiator. To give the fans a chance to cool the radiator more than if the thermoswitch were in the bottom radiator hose because the water temperature would be much hotter than 185 at the top of the radiator than the bottom.
I would like to find a thermoswitch to put in the thermostat housing instead of the upper radiator hose. I think a Z-car thermoswitch would work, but don't know the set-points of those switches. Does anybody know?
jovial_cynic
Post by jovial_cynic » 29 Mar 2016 13:19
Sound deadening!
First things first, I had to replace a floor pan that was poorly installed. I picked up a bead-roller and rolled some beads into the sheet. Nothing too fancy - just enough to give it some rigidity.
With a proper floor, I got to work on some sound deadening. This first shot shows the different layers of sound reducing materials: deadener (to stop the panels from wobbling), mass-loaded vinyl (to stop sound from penetrating through), and a decoupler (to separate the MLV from the sheet metal).
MLV over every square inch:
Home Depot carpet laid out:
Same carpet tucked in:
My wife found some stock floor mats for me a few years back:
Post by two_68_510s » 29 Mar 2016 13:36
Love the scientific approach, then BOOM, you drop the mat!
jovial_cynic
Post by jovial_cynic » 29 Mar 2016 14:22
In other news, I turned this spare side marker light into my starter button/shift-knob:
As you may notice, I made the starter button/shift-knob BEFORE I put in the carpet. I just posted them in reversed order.
toylet
Post by toylet » 29 Mar 2016 20:39
restored some 16s for the 510
new 16s.jpg (84.38 KiB) Viewed 1326 times
