| Author |
Message |
72dat
Joined: 28 Dec 2004, 18:09 Posts: 145 Location: Surrey, BC
I am looking to repaint my 72 datsun 2dr and i remember seeing color codes posted on here a while back but can no longer find them. The color is orange but i cant recall if there were more than one color code for orange. Would anyone know or could provide the color code for orange?
thanks.
| 23 Jun 2009, 04:50 |
Joined: 27 Nov 2007, 04:58 Posts: 1615 Location: Laguna Beach, Ca
Do you know the number? It is stamped in the top of the radiator support (next to the female part of the hood latch). You might try here... http://www.automotivetouchup.com/choose ... l%20Models
_________________ Finished is better than perfect......
| 23 Jun 2009, 05:02 |
72dat
no, i couldnt find anything of the top of the radiator support. The web site shows three orange colors. It's a start. Which orange was most common for datsun?
| 23 Jun 2009, 06:39 |
Joined: 02 Jul 2003, 07:06 Posts: 8884 Location: New Westminster BC
Here's what I have...
Hope it helps.
EDIT - Colour chart now higher resolution
| 23 Jun 2009, 08:07 |
Did your car originally have a white interior? I will take a pic of mine so you can see if it is the same - and I can give you my paint code.....
| 23 Jun 2009, 13:47 |
Here is a photo of a car I used to own (and wish I hadn't of sold). Same color as my current car - I will check the code today when I get home..... This is the other orange (burnt orange).
| 23 Jun 2009, 14:08 |
72dat
yes, the original interior is white. here is a pic of the color of my car. There not the best pics but you see the color.
| 24 Jun 2009, 05:33 |
72dat
bryon, what is the orange color code in the first column third row from the bottom? 092? Can't read the numbers. thanks.
| 26 Jun 2009, 05:11 |
That would be Paint Code 022
I'll see if I can download a higher res pic of that chart.
EDIT - Ok if you double click on the paint code chart in my above post, you should get a much larger hi-res picture now.
| 26 Jun 2009, 05:39 |
72dat
Thanks Byron, I'm pretty sure that the color code of my car. Thanks.
| 26 Jun 2009, 13:42 |
